tension rod bushes?
have a little hard breaking wobble similar to that I had in my other zed when I got it which went after changing the tension rod bushes. I had the whiteline ones last time I see zcenter are selling es ones now which are in 2 parts. Would these be easier to fit or is it better to get the one piece pressed in ones?
Es(energy suspension) anyone used these? I gonna order them off dan if they're good otherwise the whiteline ones
I think that they are all *******s to get out unless you have a press. I have changed mine for the solid type in the hope that I will never change them again.
So probably best go for the 2 piece energy suspension ones then? They are solid eurethane ones like these http://www.zcentre.co.uk/shop/product_info.php?cPath=21_28_58&products_id=164&osCsid=bd2deebe386e0e8bfc80807f3fcb7503
Dta dan sells these I believe
Yes, I do indeed! They are in fact 3-piece and not too bad to get pressed back in as they do come with "lubricant". I would need to order these in but expect around the £40 mark for a set.
Regards,
Dan
