Somebody help me please!!! My Rear lights have gone
One problem after another,,, the zed is slowly killing me.....
just managed to fix the drivers door window,, as it didnt open,,, turned out to be the black box,, so whacking it a few times and then tapping the wires hard into the connector have seemed to fix that issue..
but now my rear lights have gone...
My rear normal lights are have both gone off, bulbs are fine, fuses in main fuse box and fuse box near accelerator are all fine,,, all checked no problem there
brake lights working and indicators still working,, headlamps etc still working
just rear lamps.
I figure I have done in the sensor as i was messing around with rear lights as I was working on designing some different lights for the back... should just leave things alone shouldnt I....
Where is the rear lamp sensor, and is there one for both sides,,, and most importantly where would i buy them for???
I would really appreciate some help and guidance, advice
Thanks in advance guys
I had this problem with my brake lights. Sometimes they would work, sometimes they wouldnt.
Turned out to be the little black box - not sure where you can get them new (maybe nissan) - but I got one off someone who was breaking their car and its sorted the issue....
Possibly try Paul @ SWZ (breakers) and check if he has one lying about you could buy and try....
Just the one little black box on the drivers side, rear lights, behind the plastic cover.
