DIY boost leak detector
Thinking ive got a small hissing noise leak, ive searched on here and have made a very cheap DIY one.
1. Coffee jar lid from i think it was either nescafe or iceland. drill 8mm hole in.
2. cut valve from old bike tyre tube
push the valve through the drilled hole, quite tight but will give good seal. Make sure to go in from the top of the lid as the base will make it easier to remove.
Undo clip that holds the MAF housing, and squeeze in, perfect fit,
Took me less than five mins to make and at a cost of nothing. Have only tried with foot pump at the mo, but have found the leak already. If using a pressure line i will see if the valve has a good seal.
Stu
great bit of DIY.i'm off to find a coffee jar.
  • 10 months later...
How come the air dosnt escape. as will it not just go through the engine????
Great idea btw :)
