345mm big brake upgrade, stage 3
Well it's fitted at long last!
Before.
After :D :hyper:
A closeup. Bear in mind these wheels are 18" there's not a lot of room left :eek:
Old vs. new comparison :wack: :smash:
:duffer:
Edited by dunk300zxtt
  • Replies 37
  • Views 1.6k
this is a great upgrade. i would be interested if you were planning on producing a few kits. however i have a series 1 N/A. i guess i would need tt calipers too?
so whats stage 2 then? or stage 1 for that matter. and who made up this stage malarky?
The only thing is, these only just squeeze under 18" rims. I have some 17"s on the red car which I was going to try on just to have a look but there is no chance at all they will fit.
I've even had to put 3mm spacers on because the caliper slightly fouled the wheel spokes.
@ Alex, I think so yes. These discs are 30mm thick which is the same as the stock TT discs so I guess you would need TT calipers too.
@ Jimmy.... Stage 1 was sourcing the discs, stage 2 was working out and making the mounting brackets, stage 3 was fitting them :D
What can you do for the rear discs now?
The rear discs are far more of a problem since they incorporate the handbrake mechanism.
This happens to be a shoes/drum assembly, so the chances of finding another car with all the correct dimensions are very slim I would think.
It took me enough time to research to find the front discs :mac1:
Rob,
As far as I know, the KSport 330mm discs are compatible with the stock handbrake mechanism. I can double check for you if that would be of any use.
Regards,
Dan
Yep they Ksport will fit but you will have to fabricate a bracket to fit with the std calipers
  • 1 year later...
is there any info on the discs. what and where to buy pretty please?? :) can make my own relocating brackets :D
Great work, may be back to you shortly regarding making up a kit. I'll be breaking in the V8 with the standard TT disc and pads/calipers but really want to get those willwoods on
