slicktop weight vs swb targa
Is the slicktop lighter than the swb targa model does any know buy how much just wondered.:)
Not a huge amount - 30kg , providing spec is the same. Although a lot of slicktops came with other weight saving measures that would make the difference larger - manual seats, No ABS ...etc
You also have the additional stability factor to consider.
I only say this becuase if you are thinking about weight saving you are probably also thinking about performance aswell.
well that makes my LWB with me driving lighter that most SWB with their drivers
the slicktop is around 100kg lighter than a LWB targa ;)
BTW how much does removing the aircon save?
16kg. Not as much as most would expect I imagine...but there is ofcourse the added airflow/cooling benefits to its removal.
too much in my case. i think no-aircon and koyo rad makes it run a little too cold.
not when i take my roof off and leave in the garage it isnt lol
Have you changed your Thermostat yet though?
1kg = 2.2 Pounds
14 pounds in a stone.
so air con weighs 2 stone? or is my math crap
no not yet forgot where itt was in the engine :)
Yeh, 2 stone
Thats the Pump, Bracket, Condensor, Radiator, pipes
There is the aircon unit under the dash to, that could be removed, and thats another 4kg
still tring to sort a broken wire that decided to break right at it base and in a fiddly place. Bloomin cars.
