Realy having fun with this Z,today i found
that me reversing lights not working,had a good look at the wiring,could not see a problem,then it dawned on me, i have a 99 spec rear lights,but,the centre panel is black(painted out)sure enough,this was the problem,they worked but you will never see them:rofl:.So what to do! Drill Saw a hole 28mm next to(not too close as you dont want both bulbs touching or and not able to push the reverse light all the way)the indicator light(lower clear reflector on mine)then push in place,do same other side and thats it,5 mins job done and it fits nice and tight too,no need to cut out any staggerd recess for it to lock in place,Plastic is very soft when cutting,carefull not to use too much pressure or you run the risk of damaging the reflector when going through.Looking at it i cant see why this can not be done for a rear fog light too,saves having one of those fix to body yourself dangly jobs.
Tony:cool:
ps,found i have auto box sump plug too:dance:
the rear fog is actually one of the reversing lights. If you take that panel apart you will see one of the bulbs is red.
Just been out to check,and i think it may have been alterd at some point,as i have 2 rear fog either far end,then now 2 reversing lower clear,indicators clear side,then side lights upper,then brake lights upper
Tony
Aaah, that must of been Darrens Handy work, the rear panel wasn't painted when she was mine. He must have done it all at the same time.
Tony
What the king of rattle cans , i can,t believe that ( he say,s sheepishly whilst whistling and sculking away )
Come on you know what Daz is like , if it stopped still long enough it either got painted or speed holes :x::x:
