If you take the CD player out there's usually some sort of release button at the back or on the sides.... that's what I've found before
unplug the power cable, leave it a few minutes, then plug it back in without the front on. all the ones ive come across eject the disc as soon as the power is supplied to the unit. if it doesnt, then its a case of stripping it down & doing it manually.
You're a bloody genius with things like this Paul :bow: :bow: :bow:
Mario- will it work if I disconnect battery? easier to access??
it should do unless you have a power cap. give it a try. but make sure the front panel is either flipped down, or removed before you do it.
thats what you get with yeaaaaars of practice. lol
