Series 1/2 N/A clocks
Hi,
Will a series 1 clocks fit in a series 2? both non turbo.
Vijay
Someone must have had this problem? :(
I got series 2 clocks for my series 1 but they had different plugs on them so i swapped the gauges over as was the easiest way.
Cheers bud. It's the speedo that's faulty and can't swap them :(
cos his speedo is faulty and it's a series 2, I have a series one set of clocks :(
he means just swap the speedo unit - all of the gauges within the cluster are interchangeable...
Hi,
Vijay
so, yes!!
cos I have been told the speedo connections are different. Anyone know for sure?
Well I found this with Stevie007's car, the connections looked nothing like the ones on the back of the UK cluster. I had a set of UK S1 clocks to fit in. Yes the plugs were all different but the actual clocks were different too.
His was a 180kmh set, mine was the UK 180mph set.
But, having said that, on my black car it had S2/S3 Nismo 300kmh clocks, I bought a S1 UK set and swapped over the dials no problem at all.
I think the UK set will fit in a 300kmh setup, but not a 180kmh setup. Can anyone correct me on this?
the clocks in this case are both from NA's so both Jap ;)
