Removing the rear brake back plate etc.
Right, finally managed to get the rear wheel bearing lock nut undone and now I can't work ot how to get the rest apart.
I have tugged, pulled, hit and shouted at it but I can't get anything else to budge!
Any help/ideas would be greatly appreciated.
Cool - thanks.
Do I have to remove all the springs etc to get to them? (are they hidden behind?)
Cool - thanks.
:confused:
Im guessing you have sold the rear brakes and handbrake mechanism/backplates to a 200sx owner ?
In which case you need to remove the hub from the subframe (17mm and 19mm nuts and bolts on each arm) . Undo the Large driveshaft nut...knock the driveshaft off.
Your then with the complete hub carrier and rear brakes (caliper, discs, handbrake mechanism/backplate).
You can either send them that, or you can also remove the hub carrier as well - undo the 4x17mm nuts on the back and the 24mm nut. Pull off the hub carrier and send them whats rest.
Edited by Yowser
Yes a 200sx owner want them all.
Thats great thanks. Be glad when I have finished breaking this Zed - never again!!
