Probs With pc? This Site Not Loading Properly ??
Press Ctrl + F5 to refresh from server side.
That may help
im sure its the 2 after the www mate, i think it was a temporary version of the site from when Pete did the work Sunday morning. remove that and see if it works
Ah yes, the control F5 worked :D thanks guys!!,
Will change the addy too !
Still not right
Thats right! It will all come back into line when DNS sorts itself out. Most people will be already in sync but some obviously are not. Their isnt alot you can do about it yourself because it depends on how often your ISP keeps their DNS caches. Some can be as long as 7 days.
Its all to do with cached information.
Still not right
www2.300zx.co.uk is correct.
If your DNS is updated then http://www.300zx.co.uk will goto the new server, if its not you will go to the old server and be redirected to www2
I hope that makes sense
Still not right
I've got similar problems, when I use ctrl+f5 it corrects the current screen but when I go to a new page the problem comes back!!!
That's strange, it's now working OK so everything seems hunkydorey!
run this locally
start - run
ipconfig /flushdns
your ISP shouldn't cache for any longer than 8 hours, 4 hours is pretty standard now and I've never heard of a 7 day cache.
the above command will flash any dns windows has cached, you should also clear out your browser cache, it is more likely to be related to a cached page than anything else :)
hi Pete
nameservers are not configured correctly
http://www.checkdns.net/quickcheck.aspx?domain=www.300zx.co.uk&detailed=1
NS list mismatch: registration authority reports that domain is hosted on the following servers: 'ns2.vecter.net; ns1.vecter.net', but DNS server ns1.vecter.net reports domain to be hosted on 'ns1.300zx.co.uk; ns1.vecter.net; ns2.300zx.co.uk'. Please make sure that you configure the same DNS servers in registrar database and on your DNS
this may cause problems like some people are seeing with propagation, it may also cause some ISPs not to fully resolve the A/cname records in your zone file correctly.
