One piece prop shaft
Hi guys just a quick quiestion about fitting the one piece prop.
Have to remove the heat shield to fit the new prop, will it fit back over the new prop or can I just bin it?
Is it just to protect the centre bearing? or does it do something else?
Darrell
OK not good to remove if the cats are still there then.
Will it fit over the new prop?
Darrell
Yes,
I have a 1 piece carbon fiber prop, the heat guard fits fine over it.
Yes,
Cheers for that. A cracking photo to show it.
How clean is the underside of your car.
Darrell
It's not clean at all, I haven't cleaned it yet. I'm going to clean it all and underseal the lot of it. But it is a Jap import so I guess it didn't have to put up with all the salt on the UK roads for 10 years of it's life before it came here. You can always tell if it's a UK or Jap model by the rust or lack of under the car :).
