Recimp = Dump valve
Is it possible to set uyp the standard recircs to dump-to-atmosphere than dump--to-metered inlet?
I borrowed some HKS SSQV but had to go bacvk to Recircs.
Can i just bung up the recirc inlet and leave the recirc open like a dump valve - would this work?
No unfortunately this does not work because the recirc valves which are diaphragm operated and will leak at tick over ( high intake vacuum) what you need is piston activated valves which will not leak at tick over, in other words dump valves.
Robertz
