water leakage....help please
- No registered users viewing this page.
Popular Posts
ADAMZX's OEM+ 2000spec Version R Replica Conversion & Rebuild Project Build Thread
LAST STEP: THE BRAKE BLEEDING PROCESS – I HOPE THIS WORKS!
Right, it's finally time for the moment of truth! After 12 months of waiting, the brakes on my Z are finally set up in the correct orientation, and the last step in the process is to bleed all the air out of the braking system.
If everything goes according to plan, my brakes should finally be functional again, which means I'll be able to drive my Z for the first time in 12 months. I honestly can't wait!
If you've been following my build blog so far, you'll know that the last time I attempted to bleed the braking system, I tried an incredible 11 times before eventually giving up. So, let's hope that attempt number 12 is the lucky one!
First things first, I wanted to get my Stillen service cover installed over the front end of the Z to protect the paintwork from any accidental brake fluid spills that might occur during the bleeding process.
While the car was still up in the air, I also took the opportunity to reinstall my Z1 Alloy rear engine under shroud panel onto the underside of the car.
https://i.postimg.cc/FRJQdbmY/1-Z1-Rear-Undershoruds-Install-(Before).jpg
https://i.postimg.cc/0QJqMGxM/1-Z1-Rear-Undershoruds-Install-(After).jpg
BRAKE BLEEDING PROCESS (RHD VEHICLE) – USING A POWER BLEEDER
https://i.postimg.cc/TPMjvf1M/Service-Manual-Brake-System-Precautions.jpg
According to the Japanese Factory Service Manual (FSM), the brake fluid should be inspected every 10,000 km (6,000 miles) and replaced every 40,000 km (25,000 miles).
For this job, I'll be following the brake bleeding procedure outlined in the FSM, which can be found on page MA-25 of the JDM manual or page MA-20 of the USDM manual.
https://i.postimg.cc/nrbfvsc6/2-Task-4-Bleeding-Brakes-(LH-Rear).jpg
I've numbered each stage of the bleeding procedure to correspond with the illustrations in the FSM. This should help ensure that I follow the correct bleeding sequence for my right-hand-drive (RHD) JDM vehicle.
https://i.postimg.cc/4dhT7vZg/2-Bleeding-Sequence-including-ABS.jpg
The first step was to top up the brake master cylinder (BMC) reservoir with fresh Super DOT 4 brake fluid.
https://i.postimg.cc/T1MvryYc/2-Brake-Bleeding-Process-(Master-Cylinder-Topped-Off).jpg
Next, I connected my specialised power bleeder tool to the brake master cylinder. My 2000-model brake master cylinder requires a specific Nissan adaptor cap, which replaces the original yellow reservoir cap and provides the hose connection needed for the power bleeder.
Once everything was securely connected, I used the pump mechanism on the tool to perform a dry pressure test of the braking system. This would allow me to check for any leaks in the brake hoses and lines before introducing fresh brake fluid and beginning the bleeding process.
I pressurised the braking system to a maximum of 15 PSI and, once the required pressure had been reached, left the tool alone for at least two minutes to see whether it could maintain that pressure.
https://i.postimg.cc/8cQghFz8/2-Brake-Bleeding-Process-(Setting-Up-Tool)-1.jpg
If the pressure reading on the power bleeder's gauge dropped during the two-minute test, this would indicate a potential leak somewhere within the braking system that would need to be investigated and rectified before proceeding.
https://i.postimg.cc/L5KFzq6b/2-Brake-Bleeding-Process-(Set-to-15-PSI-and-Holding-for-2-mins)-2.jpg
Thankfully, the results of the dry pressure test were exactly what I was hoping for! There was absolutely no noticeable drop in pressure after the two-minute test, indicating that the system was holding pressure as expected.
With the test complete, I slowly released the pressure from the power bleeder by loosening its fluid cap, allowing the compressed air to escape and the system to depressurise.
With the initial pressure test successfully completed, I then filled the power bleeder's reservoir with approximately 200 ml of fresh DOT 4 brake fluid and repressurised the tool to 15 PSI.
Everything was now ready to start bleeding the first brake caliper!
Because my Z is a right-hand-drive vehicle, the bleeding sequence starts with the left-hand rear brake caliper, followed by the right-hand rear caliper.
BLEEDING THE REAR BRAKE CALIPERS
I connected a brake fluid catch bottle to the rear brake caliper's bleeder valve and used a 10 mm flare nut wrench to carefully loosen the valve, allowing the brake fluid to flow out of the caliper and through the clear tubing into the catch bottle.
One of the biggest advantages of using a power bleeder is that I can carry out the entire bleeding process without needing someone else to pump the brake pedal.
The tool applies constant pressure to the braking system, so once the caliper's bleeder valve is opened, brake fluid automatically starts flowing through the system and out of the valve.
Because the power bleeder also has its own reservoir of fresh brake fluid, it can continuously replenish the master cylinder as the old fluid is pushed through the system. This helps prevent the master cylinder reservoir from running dry and introducing additional air into the braking system.
https://i.postimg.cc/nrbfvsc3/2-Brake-Bleeding-Process-(Rear-LH-RH-Calipers).jpg
BLEEDING THE FRONT BRAKE CALIPERS
Next up were the front brake calipers.
Just like the rear calipers, the bleeding sequence for my RHD vehicle starts with the left-hand front caliper, followed by the right-hand front caliper.
https://i.postimg.cc/HnD1QJs4/2-Brake-Bleeding-Process-(Front-LH-Caliper).jpg
BLEEDING THE A.B.S ACTUATOR
The final component in the bleeding sequence was the ABS actuator, which is located in the rear boot on the right-hand side of my 2+2 model.
To gain access to the unit, I first had to remove the trim cover that sits over the ABS actuator.
The actuator has two bleeder valves: one on the front side and another on the rear side. According to the FSM, the front-side valve must be bled first, followed by the rear-side valve.
https://i.postimg.cc/Px8kpbhv/2-Brake-Bleeding-Process-(ABS-Unit-1).jpg
https://i.postimg.cc/QCGZpBxT/2-Brake-Bleeding-Process-(ABS-Unit-2).jpg
With the ABS actuator bled, that officially completed the entire brake bleeding procedure!
I was really happy with how everything had gone so far, especially considering the amount of trouble I'd experienced during my previous attempts.
Naturally, my first thought was to test the brakes and see whether the spongy brake pedal symptoms that had been giving me so much grief were finally gone.
With the car still sitting on all four jack stands, I started the engine and let it idle. I then pressed down on the brake pedal to see how things felt.
To my delight, the pedal immediately felt much firmer than before, and it no longer travelled all the way to the floor. I was absolutely over the moon!
However, that excitement didn't last long because the brakes suddenly locked up completely, and my initial feeling of joy quickly turned into a familiar sense of dread.
I immediately switched off the engine and inspected the braking system at both the front and rear of the car to figure out what had gone wrong.
And this is what I found!
https://i.postimg.cc/yxm4nVD6/3-Rear-rotor-Jammed-after-quick-test-mistake-2.jpg
As it turned out, I'd accidentally managed to jam both rear brake rotors after they had partially walked off the wheel studs during my brake test.
Looking back, I should have reinstalled the rear wheels before attempting to test the brakes. Unfortunately, I hadn't thought about this beforehand, and now I was left with a rather unpleasant predicament.
Both rotors were jammed incredibly tight, and I needed to figure out how to get them back into position.
I eventually decided to call my Dad and ask for his advice. His response was pretty straightforward:
"Just bash the rotors back into place!"
Fortunately, I had a dead-blow hammer handy, so I followed his advice and gave the outer edge of the rotor a few firm taps.
Thankfully, that did the trick! The rotor eventually popped back into position against the wheel hub, and I was relieved to see that I'd managed to free it without any further drama.
https://i.postimg.cc/BbT9NqjG/3-Rear-rotor-Jammed-(Fixed)-2.jpg
Thank goodness for that, because I was genuinely worried I'd created an even bigger problem for myself!
I repeated the same process on the opposite side, and once both rear rotors were back where they belonged, I decided it would be a good idea to reinstall the rear wheels before carrying out any further brake testing.
INSTALLING THE FRONT & REAR ROAD WHEELS
With the rear rotors sorted out, I reinstalled both rear wheels onto their respective hub assemblies.
All the wheel nuts were then tightened and torqued to 100 Nm each, following a star pattern to ensure the wheels were secured evenly.
https://i.postimg.cc/KjPSQZ1Y/4-Lowering-Onto-Ground-(Rear-Wheels-1).jpg
With the rear wheels installed, I decided to carry out another quick brake test.
This time, everything was looking much better!
The brake pedal felt firm, and there was no longer any excessive pedal travel when applying pressure. I also noticed that both rear wheels, which had been spinning freely while the engine was idling, would now stop spinning when I applied the brakes.
That was exactly the result I was hoping for, and I was absolutely over the moon with how things were turning out!
The only thing left to do now was reinstall the two front wheels and finally lower the Z back onto the ground after it had spent at least 12 months sitting up on jack stands.
https://i.postimg.cc/8kMSTbtH/5-Lowering-Onto-Ground-(Finsihed)-3.jpg
https://i.postimg.cc/kGQ3wn2V/5-Lowering-Onto-Ground-(Finsihed)-2.jpg
FINALLY, MY Z IS BACK ON THE ROAD!
With all four wheels reinstalled and the car finally back on the ground, it was time for the moment I'd been waiting 12 months for.
I took the Z out for a test drive, and the difference was absolutely night and day!
The brakes were finally working as they should, with the car able to come to a complete stop using what felt like the expected amount of pressure on the brake pedal.
After 12 long months of waiting, countless headaches and 11 failed attempts at bleeding the braking system, I finally had my Z back!
I honestly can't describe how satisfying it was to finally get this problem resolved. It's been a long and frustrating journey, but seeing the car back on the ground and being able to drive it again made all the effort worthwhile.
I also learned a valuable lesson from this experience: always make sure the wheels are installed before carrying out any brake testing with the car running!
With the brake situation finally resolved, I can now turn my attention to the next problem that still needs addressing – the transmission!
Hopefully, that won't turn into another 12-month saga!
Stay tuned for the next update!By DJ_Party_Favor ·
FIXING MY CAR'S SPONGY BRAKE PEDAL ISSUES ONCE AND FOR ALL
With both of my front and rear brake caliper restoration projects now on hold for the time being, it's time to shift my focus towards getting my Z back on the road. However, before I can do that, I first need to finish diagnosing and resolving the spongy brake pedal issue that has plagued my car for the better part of the last 12 months.
The problem originally surfaced during what should have been a relatively straightforward brake pad replacement and brake fluid system bleed. Unfortunately, following the work, my car's brake pedal developed an unusually soft, spongy feel with excessive pedal travel. The brakes were barely capable of bringing the car to a complete stop, making it unsafe to drive and forcing me to take the car off the road until I could figure out what was causing the problem.
After struggling to identify the cause of the spongy brake pedal issue myself, I decided to seek assistance from a local mechanic to see if he could help diagnose the problem. Unfortunately, even with his expertise and specialised equipment, we were still unable to pinpoint the cause, and my car's brake pedal continued to feel spongy no matter what we tried.
Since December 2024, I've spent countless hours researching the various causes and symptoms associated with a spongy brake pedal. I've also spent months pulling apart and inspecting various braking components in an attempt to get to the bottom of the problem.
Well, after all this time, the mystery has finally been solved!
I can now reveal exactly what was causing my car's spongy brake pedal issue, and the answer was something I had overlooked right from the very beginning. In fact, I can explain the entire problem with just one simple photo.
https://i.postimg.cc/mrFVrCsn/0-Brake-Caliper-Issue-Discovered-Feb-25.jpg
Yes, you guessed it! My front brake calipers were installed upside down!
I have to admit, I feel like a complete idiot for overlooking something so obvious, especially considering how much time and effort I've spent trying to diagnose this problem.
So, how exactly does installing a brake caliper upside down cause a spongy brake pedal?
The problem comes down to the location of the brake fluid inlet and, more importantly, the position of the caliper's internal bleed point. When a brake caliper is installed in the wrong orientation, the bleed point can end up below the highest point of the internal hydraulic passages. This creates an air pocket that cannot be effectively removed through the normal bleeding process.
In other words, no matter how many times you attempt to bleed the braking system, trapped air can remain inside the caliper because it has nowhere to escape.
For the bleeding process to work correctly, the caliper needs to be installed in its intended orientation, with the bleed nipple positioned at the highest point of the hydraulic cavity. This allows trapped air to escape as brake fluid is pushed through the system.
As it turns out, this was exactly what had been happening with my car.
What's even more interesting is that I actually discovered the problem completely by accident!
One day last month, I randomly decided to look through some old archived photographs from my 2Kspec conversion build project. While browsing through the photos, I came across an image taken shortly after I had installed a freshly painted set of front brake calipers and BDE rotors onto the car.
After taking a closer look at the photo, I noticed something that immediately caught my attention.
The brake fluid hose connection on the back of the original front brake caliper was positioned at the top of the caliper.
https://i.postimg.cc/g06408pd/0-Photo-of-brake-fluid-hose-discovery.jpg
It was one of those lightbulb moments where everything suddenly started to make sense!
I immediately rushed out to the garage to inspect the front brakes currently fitted to my car and compare the orientation of my TT front brake calipers against the ones shown in the old photograph.
Sure enough, I discovered that the brake hose connections on both of my currently installed front brake calipers were positioned at the bottom of the calipers rather than at the top.
This was the breakthrough I'd been looking for!
However, there was still one question I needed to answer.
My Dad was the person who installed these TT front brake calipers back in February, so how had he managed to install them in the wrong orientation?
Unless, of course, the original non-turbo front brake calipers had already been installed upside down to begin with, and he had simply transferred the replacement TT calipers across in exactly the same orientation without realising anything was wrong.
That's when I finally pieced together what had happened over the course of the previous seven years.
And as it turns out, this entire mess was actually my own fault!
You see, the original mistake happened all the way back in 2017.
At the time, my car had been experiencing some pretty severe brake shuddering symptoms for several months. After determining that my existing BDE TT front brake rotors were badly worn and warped, I decided to temporarily remove them and install an old set of non-turbo front brake calipers and rotors that I had lying around.
The plan was simply to get the car back on the road until I could afford to purchase another set of replacement TT front brake rotors.
Unfortunately, during that brake job, I made several rookie mistakes. One of those mistakes was allowing the brake master cylinder reservoir to run completely dry of brake fluid. Looking back now, I also realise that I must have installed the replacement non-turbo front brake calipers upside down without even knowing it.
After putting everything back together, I attempted to drive the car home, only to discover that the brake pedal had developed that same horrible spongy sensation. The brakes were barely capable of bringing the car to a complete stop, and I immediately realised that something was seriously wrong.
Fortunately, I managed to limp the car back to my Dad's place, where I had to wait until he returned home the following day so that we could try to figure out what had gone wrong.
What followed was an entire day spent attempting to bleed the braking system, but despite our best efforts, we simply couldn't get the brake pedal feeling right.
Eventually, I had to borrow my Dad's car for an entire week before he finally managed to get my car's brakes working properly again.
At the time, neither of us realised that the front brake calipers had been installed upside down. We had simply assumed that the problem was caused by air trapped somewhere within the braking system and never thought to question the orientation of the calipers themselves.
So, when you think about it, I've potentially been driving around with incorrectly installed front brake calipers ever since 2017!
It's a pretty unsettling realisation, to say the least. It also explains why I was never able to successfully bleed the braking system after replacing the brake pads back in December 2024. The underlying problem had been there all along, and no amount of conventional bleeding was going to completely resolve it while the calipers remained incorrectly installed.
What makes matters even more frustrating is that, during my research into spongy brake pedal symptoms, I came across multiple videos explaining how incorrectly installed brake calipers can cause exactly this type of problem.
I had actually been presented with the answer several times throughout my research, but I was so convinced that I couldn't possibly have made such a basic installation mistake that I simply dismissed the possibility.
Looking back, I really wish I had paid closer attention to that advice, as I could potentially have figured everything out months ago!
With the mystery finally solved, it's time to put things right and hopefully get my Z back on the road once again.
The plan is relatively straightforward. I'll remove both front brake calipers from the car, reinstall them in their correct orientation, and then perform a complete bleed of the hydraulic braking system.
If everything goes according to plan, I should finally have a firm brake pedal and a fully functional braking system once again.
Let's get started!
Front RH Brake Caliper Removal Process
https://i.postimg.cc/3N9FqZXn/FSM-Front-Brake-Caliper-Removal-Process-Illustration.jpg
I'll begin by removing the front brake caliper currently installed on the right-hand side of the car.
https://i.postimg.cc/fLnCSyW4/2-Brake-Pad-Removal-Process-1-RH-(Start).jpg
The first step was to remove all the brake pad retaining hardware before removing the two brake pads currently installed inside the caliper.
https://i.postimg.cc/SsFdYRQX/2-Brake-Pad-Removal-Process-2-RH-(with-Tool).jpg
https://i.postimg.cc/fLcKcskm/2-Brake-Pad-Removal-Process-4-RH-(Pads-Removed).jpg
With the brake pads and retaining hardware removed, I could now move on to disconnecting the brake fluid hose located at the rear of the caliper.
https://i.postimg.cc/ZR8c8m0H/3-Brake-Hose-Disconnect-1-RH-(Start).jpg
To avoid damaging the hexagonal brake line fitting during removal, I used a dedicated 10mm flare nut spanner. This type of spanner provides better contact with the fitting than a conventional open-ended spanner.
https://i.postimg.cc/tT353b7r/3-Brake-Hose-Disconnect-2-RH-(Tool).jpg
Also after disconnecting the brake hose, I fitted a specialised brake line clamp tool to minimise brake fluid leakage from the disconnected hose line.
The final step was to remove the two mounting bolts securing the brake caliper to the wheel hub assembly.
https://i.postimg.cc/13SNFFwb/4-Brake-Caliper-Removal-Process-1-RH-(Start).jpg
With both mounting bolts removed, the front right-hand brake caliper could finally be lifted away from the wheel hub assembly.
https://i.postimg.cc/50B3BJjD/4-Brake-Caliper-Removal-Process-2-RH-(Caliper-Removed).jpg
Front LH Brake Caliper Removal Process
With the right-hand side caliper removed, I repeated the same procedure on the opposite side of the car to remove the front left-hand brake caliper.
https://i.postimg.cc/5yfmprFD/5-Brake-Pad-Removal-Process-2-LH-(By-Hand).jpg
https://i.postimg.cc/htn7mmTH/6-Brake-Caliper-Removal-Process-2-LH-(Caliper-Removed).jpg
With both front brake calipers now removed from the car, I could finally begin reinstalling them in their correct orientations.
Front LH Brake Caliper Installation Process
https://i.postimg.cc/cCTBzcRm/FSM-Front-Brake-Caliper-Installation-Process-Illustration.jpg[/img]
Since I'm already working on the left-hand side of the car, I'll start by reinstalling the front LH brake caliper onto the left-hand wheel hub assembly.
After positioning the caliper into place, I prepared the mounting bolts for installation.
https://i.postimg.cc/kG7ywHb4/7-Brake-Caliper-Installation-Process-1-LH-(Start).jpg
https://i.postimg.cc/j2v41hHf/7-Loctite-Applied-to-Caliper-Mounting-Bolts-1(Start).jpg
https://i.postimg.cc/J7QxtR9S/8-Loctite-Applied-to-Caliper-Mounting-Bolts-2(During).jpg
I applied medium-strength (blue) Loctite to the caliper mounting bolt threads to help prevent them from loosening over time. The mounting bolts were then installed and tightened according to the manufacturer's specified torque requirements.
With the caliper securely mounted in its correct orientation, I could move on to reinstalling the two front brake pads and reconnecting the brake fluid hose to the rear of the caliper.
https://i.postimg.cc/WzSwy7G2/7-Brake-Caliper-Now-Installed-Fully-LH-(End).jpg
https://i.postimg.cc/J0K5FQN0/7-Brake-Hose-Installation-Process-2-LH.jpg
With everything back together, the front left-hand brake caliper was now correctly installed!
Front RH Brake Caliper Installation Process
With the left-hand side completed, I repeated the same installation procedure on the right-hand side of the car.
https://i.postimg.cc/D05PNcrL/8-Brake-Caliper-Installation-Process-1-RH-(Start).jpg
https://i.postimg.cc/D05PNcrd/8-Brake-Caliper-Now-Installed-Fully-RH-(End).jpg
https://i.postimg.cc/y6TjW7w5/8-Brake-Hose-Installation-Process-2-RH.jpg
And with that, both front brake calipers are finally installed in their correct orientations!
After months of troubleshooting, researching and pulling apart various braking components, I've finally managed to identify what was causing my car's persistent spongy brake pedal issue.
There is just one last thing left to do before I can find out whether all this work has actually paid off.
It's time to perform a complete bleed of the hydraulic braking system and see if I can finally get that firm, consistent brake pedal feeling back again!
To be continued...By DJ_Party_Favor ·
FRONT BRAKE CALIPER SANDBLASTING PROCESS
I'm now nearing the end of the sandblasting stage of the brake caliper restoration mini project, with only the front set of later-model TT iron brake calipers left to strip back to bare metal. Once the blasting is complete, the next phase of the restoration will be to prepare and paint the all of the front and rear calipers.
In my previous blog updates, I had already finished sandblasting the rear brake calipers. I decided to remove the brake piston dust boot covers and carried out some additional blasting in the areas that had previously been covered, making sure those sections were also cleaned back properly. With that final bit of work completed, the rear calipers were finally ready for the painting stage.
Rear Brake Calipers — Final Blasting Results
https://i.postimg.cc/NMvXqVw5/5-Rear-calipers-after-blasting-2.jpg
https://i.postimg.cc/W3cZLKPz/5-Rear-calipers-after-blasting-3.jpg
Front TT Brake Caliper Sandblasting Process
With the rear calipers finished, it was time to turn my attention to the front set of TT brake calipers.
I started the blasting process, and although it took longer than I had hoped, the first caliper half came up pretty well, if I do say so myself!
https://i.postimg.cc/T3SmQ17N/2-Blasting-process-begins.jpg
https://i.postimg.cc/DwDs50j5/3-Comparison-of-before-and-after-blasting-2.jpg
I then continued working my way through the remaining front caliper components, gradually stripping away the old surface finish until all the pieces had been cleaned back to bare metal and were ready for paint.
https://i.postimg.cc/Sx58VRTv/4-After-blasting-1.jpg
https://i.postimg.cc/Mp4RtHPP/4-After-blasting-2.jpg
https://i.postimg.cc/MGQBLwgJ/4-After-blasting-3.jpg
Unfortunately, this wasn't a quick or easy process. It took several hours of blasting to get all the components to this stage, but that's to be expected given the limitations of my budget sandblasting setup and its relatively small air tank capacity. It's a slow process, but the end result is worth the effort!
Change of Plans for the Rebuild Project
Although the sandblasting stage for all the brake calipers is now complete, I've had to make a change to my original plans for the rebuild project.
There's a major car event coming up in April, roughly six months from now, that I'd really like to attend. With that deadline approaching, I've decided it's time to shift my priorities towards getting the Z back on the road rather than continuing with the full brake caliper restoration.
Ideally, I would have liked to finish restoring both the front and rear calipers before moving on to the next stage of the project. However, with so much work still to do to get the car roadworthy, I need to be realistic about how much I can accomplish in the time available.
For now, the freshly blasted front and rear caliper components will be put into storage until I can return to the restoration and complete the painting process at a later date.
In the meantime, my main priorities over the next six months will be to get the car's braking system back into working order and address the faulty automatic transmission, either by repairing it or replacing it if necessary.
It's a little disappointing to have to put the caliper restoration on hold after all the time and effort I've invested in stripping everything back to bare metal, but getting the Z back on the road and ready for the April event has to take priority.
There will be plenty of time to come back and finish these components properly once the car is running and driving again. For now, it's time to focus on getting the Z back on the road!By DJ_Party_Favor ·
November was a big month for the build project, with me finally tackling one of the major issues that had kept the car off the road since early December 2024.
The month also saw the final sandblasting work completed on the front brake calipers, along with the installation of a new, later-model component.
However, the biggest milestone was finally getting to the bottom of the car’s spongy brake pedal issues. This involved correcting incorrectly orientated braking components before carrying out a complete bleed of the braking system.
The month wrapped up on a high note, with the car finally back on the road after almost a year off it!
YouTube Channel: https://www.youtube.com/@ADAMZX Instagram: https://www.instagram.com/adamzx_z32By DJ_Party_Favor ·
Project Black Sunshine - The 300bhp NA
Nice.
I have looked at this same fuel sending unit option for one of my own cars. Hopefully, the quality is good. What fuel pump did you go with?
Love seeing the progress, thanks.
I saw the cigarette butts next to the fuel pump sending units and couldn't help but chuckle a bit.By protoj ·
bit of a duh question this one ...encountered quite a frisky water leak this weekend.. engine was at running temp when i stopped, and steam billowed from under the bonnet, when i popped it there was lots of water fizzing from the area above the water pump, looked like it was coming from either of the cooling pipes going under the plenum above the pump.....could it be the stat housing or hopefully just a knackered hose.....Main question, how easy is it to DIY....took one look and thought id better ask on here first. Anyone know of any reasonably priced jap specialists in the gloucester area...... really wanted her up and running for japfest but that dont look too good now.....HELP PLEASE..........Cheers
