Eibach springs question
In the box i have 4 x springs to me look the same..............so are fronts the same as rears or am i missing something!:confused:
No they are different. Have a look at the numbers on the springs themselves
IIRC They have the part number stamped into them, this will tell you which is front and which is rear??
What he says ^^^^^^ :rofl:
Ignor him, he is wrong. Read my post! :D
So does this mean part no inc the word front or rear or F and or R!!
If not how can i know what part no represents front or rear !!
When your fitting them its obvious. they will not sit right if you get them wrong. The top and bottom rings are different sizes and you should be able to compare them with the ones you remove.
Not fitting them mechanic is but said to him last night that he should be able to match them up to the existing ones;)
Thanks for the help will contact him know
I thought in/on the box it told you what part number was front and what was rear?
Was a few years ago sinse I did mine though, could be wrong.
