April 1, 200818 yr What is the diference between the fuel injectors for the pre and post 1994/10 cars? The HKS list is for cars 1994/10 to 1998/10, can you not fit them to an earlier car with some modification?
April 1, 200818 yr Requires machining of the lower intake plenum and also different fuel rails - Z1 do a kit :)
April 1, 200818 yr Author Requires machining of the lower intake plenum and also different fuel rails - Z1 do a kit :) Can you use a late car fuel rail and machine the plenum to suit or maybe a late car plenum if they are different?
April 1, 200818 yr Yep its only the lower plenum you need doing :) Either machine yours/buy a machined one/buy a 94> one. Along with the 94> fuel rails of course :)
April 1, 200818 yr Author Yep its only the lower plenum you need doing :) Either machine yours/buy a machined one/buy a 94> one. Along with the 94> fuel rails of course :) As usual you know to much :bow: Guess I'll be posting something in the wanted section soon if plan B comes into force :)
April 1, 200818 yr Be extrememly lucky for a 94 onwards fuel rail and plenum to become available tbh. Another option is the 300degree Fuel rail kit.
April 2, 200817 yr Lower intake http://www.z1motorsports.com/product_info.php?cPath=6_17&products_id=945&osCsid=8c4801585b04abcd68a05d9b3dc94328 New fuel rails http://www.z1motorsports.com/product_info.php?cPath=6_17&products_id=944&osCsid=8c4801585b04abcd68a05d9b3dc94328 Total cost $323 as opposed to $450 for the 300 degree. Granted the 300 degree kit does give better fueling to all cylinders but depends how far you want to go really :)
April 2, 200817 yr Might beable to help here, last time Mark (Topless) done some work for me he said i had the late injectors etc i would assume there is no diff from an N/A or TT? if anyone has a pic i could check it against the one i have John
