det sensor code 34 connectors broke
hi i get a code 34, checked and the wires to both connectors have broke...
the ecu connector
yellow and black
the det sensor
one wire?
how do i fix the.....
how do i fix this. also my car wont boost over 0.5 bar and not over is this safety boost... as car sound and drives perfect no smoke at all???
Yep thats safety mode becuase of the code34. It will be running reduced boost, retarded timing and the safety fuel maps. Power will be considerably reduced and fuel consumption will be higher.
Can you see the break in the wires or have you done a continuity test with a multimeter ?
the black wire from the ecu connector is snapped of.. shall i just connect it back and put a resistor on it will this sort by problems out it.
if i was to do this, where do i connect the det sensor wire or do i leave it disconnected?
