How can i on Ebay
add a starting price after i have listed item forgot to b4 i advertised and now have i bid but 0.99!! on an item that worth a lot more?
any help guys!
Dave
Just end it and relist it once you've edited it :)
What about the 2 bids i have already received??
Does'nt matter, aslong as your item has more than 12 hours left you can end it :)
Then just edit it and relist :)
Fair one.. cheers buddy
No worries bud, if you are worried about upsetting the bidders then email them and tell them why you did it, however when you end it you can give a reason and then they can have a look and it will display the reason why you did it.
BTW one of the reasons for ending is you made a mistake with the start price - so you're sorted :)
Easier to remove bids then edit in it? :confused:
He can do that then, it was only a suggestion, that i know works :)
you can cacel bids as I remember as lisaf said may have to do them individually though .I think you may have to give a reason but as I remember that's all. Then just edit your starting price. Failing that end the listing cancel all bids due to listing error and restart the auction at new price as zx eyes has said. This will cost you a second insert fee though for the new listing. Either has to be done before the final 12 hours to run or you're screwed
You can't edit a listing once you have received bids, even if you remove the bids.. You may only 'add' to the description, which appears in a seperate box underneath the original description.
Better to end the auction, and re-list with the correct starting price.
