Amusing aircraft log entries ...FAF!
I found this on the 200 forum and thought that you would enjoy reading it....!
After every flight, pilots complete a gripe sheet which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The form is a piece of paper that the pilot completes and then the mechanics read and correct the problem. They then respond in writing on the lower half of the form what remedial action was taken and the pilot reviews the gripe sheets before the next flight.
Never let it be said that ground crews and engineers lack a sense of humour.
Here are some actual logged maintenance complaints and problems, known as
submitted by QANTAS pilots and the solution recorded by maintenance
engineers. By the way, Qantas is the only major airline that has never had
an accident.
P = The problem logged by the pilot.
S = The solution and action taken by the engineers.
P: Left inside main tyre almost needs replacement.
S: Almost replaced left inside main tyre.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft.
P: No. 2 propeller seeping prop fluid.
S: No. 2 propeller seepage normal. No's 1, 3, and 4 propellers lack normal
seepage.
P: Something loose in ****pit.
S: Something tightened in ****pit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 fpm descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with words.
P: Mouse in ****pit.
S: Cat installed
biggrin.gif biggrin.gif biggrin.gif Absolute CLASS!!!! biggrin.gif biggrin.gif biggrin.gif
I work at Birmingham International Airport and know for a fact that pilots are a very funny bunch of people -never known an aircraft mechanic to do anything more than "grunt" though ...
Thanks for that - it made my morning!
Dan
I like to put funny stuff up on this board to try and cheer people up as there seems to be a lot of 'bad air' from time to time?.
Glad you enjoyed it!.
Tony
