Hi all,
Need some advice where I can get something done. I need some holes cut into some 1mm metal sheet. The holes will be about 11/12 cm's in diameter and have to be an accurate cut. What sort of company should I be looking for?
Vijay
Hi all,
Vijay
Yellow pages, metal fabricators or engineering companies.
Cheers bud. Any idea what sort of engineering compay, precision?
Vijay
cheers bud :) Look like a complicated way of cutting holes!! lol
or a local engineering shop with cnc mills. it can be done very easily and cheaply!
how many holes and what "metal" is it?
Hi all,
Vijay
Hi Vijay,
There's a laser cutting CNC unit near my work - reckon that sounds a possibility.
either laser or waterjet, plasmas wont give you a massivly high quality cut.
what is it you want exactly have you drawn it up in autocad or somthing? Or have you got a drawing of it?
2 peices of 400x200x1mm steel, each of them with 2 holes cut out of them :)
Not got a drawing but can easily do that
try these guys off uxbridge road in southall. they do everything like that.
Ring Engineering
Engine Rebuilding & Reconditioning (Workshop & Repair Centres) based in the Beaconsfield Roadarea of Hayes
Tel: 020 85614553
Address: Unit 15 Tudor Works, Beaconsfield Road Hayes Middlesex UB4 0SL
View Ring Engineering's profile
Vijay. this is a serious question. what tolerance you after?
To be honest any shop with a CNC or waterjet system would be able to do the job for you
I've allowed 3mm for any problems. Went to 3 engineering shops today, 2 said they couldn't do it and the 3rd wants 60 quid.
Vijay
Vijay
how much :shock: shame your so bloody far away!!
btw 3 mm is a huge tolerance :rofl:
I've been told I have to allow for 1mm of paint on the edges on the inner edges so will reduce it by 2mm. 1mm Sounds a lot for paint though :( That's how I got the 3mm tolerance
3mm. mate if you have allowed that center punch it and do it yourself. Way yoou where talking I was thinking 0.001"
Think I've got that wrong, if you mean how much can the engineering shop be out, I want it perfect down to a hundreth of a mm
Is there an adjustable hole cutter than will cut 1mm steel sheet that I can use myself?
if you want it that perfect then youl need a shop to do it. It probably take them 20 minutes to set up and your looking at £50-100. iF you want it done cheaper than that youl have to get lucky or know a mate in the trade.
cheers bud, think I'll be paying the 60 quid to get it done properly ;)
Ask your local university or college. They'll have all the equipment necessary for this sort of thing.
