2x2 prop shaft
hi guys just wondering is dr a difference in the lenths between swb and 2x2 propshafts ?
yes, the front half is longer/shorter. Rear half is the same.
edit: its the rear half that is shorter
ok, I was wrong. The fronts are the same, the rear is shorter on a SWB,
i would think its the front as the gearbox's are different ??
Gearboxes are the same.
Really? Maybe i'm confusing N/A to TT then ??
Auto, Manual, TT, NA, LWB, SWB all different combinations of front and rear props. Its a bit of a headache sorting the correct prop out for each application.
