Wanted - wheel studs and nuts
Best go to Nissan I think the studs are about £4 each and nuts are about £1.50 each you will need to tell them if there for the front or rear as there different sizes. The way I changed mine was to bang old ones out with hammer then push new back through but to get them where they should sit is difficult I done this by using a ring spanner over stud that sticks out of hub put nut on and tighten bolt letting it dig into spanner and slowly stud will sit in perfect, best buy or use old nut for that as it wont be much good after!
