February 3, 200818 yr i have oil pressure that drops and comes back,do i need to change the oil if so what oil is recomended. or is the switches on these cars tempromental. thanks :hyper:
February 3, 200818 yr i have oil pressure that drops and comes back,do i need to change the oil if so what oil is recomended. or is the switches on these cars tempromental. thanks :hyper: This will most likely be due to a faulty oil pressure sensor. These are prone to fail given the age of the cars. Nissan charge around £80+ VAT for these but you may as well get an aftermarket oil press. gauge. Oil wise - there are many (divided) opinions on this. I have always uses Castrol Magnatec 10W40 without any running problem (summer or winter). HTH Dan PS - Welcome to the Club!
February 3, 200818 yr i have oil pressure that drops and comes back,do i need to change the oil if so what oil is recomended. or is the switches on these cars tempromental. thanks :hyper: Hi Shippa, try this place for you sender unit,http://www.importcarparts.co.uk/parts_info.asp?id=484 Paul
thanks :hyper:
