Need cars width and length
Bloody car cover got ripped off last night and I need to get another one from Halfrauds. Need to make sure teh dimentions re correct, what are tehy for a SWB? width is 1.8meters but I cant find the length, about 4.8 maybe 5 meters looking at it?
For SWB, stats are...
Make Nissan
Model 1996 300ZX Twin Turbo
Powertrain Layout Front Engine / RWD
Base Price $33 000
Dimensions
WheelBase 2451 mm / 96.5 in
Length 4305 mm / 169.5 in
Height 1250 mm / 49.2 in
Width 1791 mm / 70.5 in
Weight 1579 kgs / 3480 lbs
Front / Rear Track F 1496 mm / 58.9 in
R 1554 mm / 61.2 in
Engine
Configuration Twin Turbocharged V6
Valvetrain DOHC, 4 valves / cylinder
Displacement 2960 cc / 180.6 cu in
Power 223.7 Kw / 300.0 bhp @ 6400 rpm
Torque 383.7 Nm / 283.0 ft lbs @ 3600 rpm
Bore 87.0 mm / 3.4 in
Stroke 83.0 mm / 3.3 in
Compression Ratio 8.5:1
BHP / Liter Not Available
Redline Not Available
Transmission
Type 5-Speed Manual
Final Drive 3.69:1
1st Gear Ratio 3.21:1
2nd Gear Ratio 1.93:1
3rd Gear Ratio 1.30:1
4th Gear Ratio 1.00:1
5th Gear Ratio 0.75:1
6th Gear Ratio Not Available
Chassis & Body
Steering Rack & Pinion w/ Power Assist
Tire Sizes F 225/50ZR-16
R 245/45ZR-16
Brake Types Vented Discs
Brake Size F 279 mm / 11.0 in
R 297 mm / 11.7 in
Available ABS Yes
Body Material Unit Steel
Performance
Top Speed 155.0 mph / 249.4 kph
0 - 30 mph 2.0 seconds
0 - 60 mph 5.5 seconds
0 - 100 mph 14.6 seconds
0 - ¼ mile 14.1 seconds
Lateral Acceleration 0.91g
EPA City / Hwy 18 / 24 mpg
You can get a nice custom car cover for the 300zx, but I can;t remeber where I bought mine from. :(
There are a couple threads on here about nice car covers for the Z
it was a custome cover, wasnt as strong as it was advertised. straps kept on breaking in the wind. They recon you needed to take it off in teh wind,,,, thats when it needs the cover most ffs.
just gona get a halfrauds one, when that breaks it wont cost an arm and leg to replace it ffs
I cover mine with dust..fits perfectly !
tehn you have your inside.... so its also covered with roof and walls.
I've used a Halfords universal jobbie on zed before...dont remember size though..but it fitted fine, had straps to hold it down, elastic ends..etc
It did unpeel itself at the front when it got really windy though...never blew away or broke straps though.
thanks fellas. I now have a very flimsy cover that I put money on becoming a parachute at some poiont tonight.
