cam covers
ells300zxtt.jpg how easy is it to get cam covers off for painting ? and is there anything else that needs to be dismantled, thanks.
You will have to remove the two metal water pipes from front of engine to get to the screws to take the left cover off.Also removal of ptu and wires to cas. The right side comes straight off. If you want the bottom metal one off you will have to remove the crank pulley and to make that easier i recommend taking off rad. There really is no need to take that bottom cover off though.
