targa blinds
Hi, can any of you fellow zedders be able to measure a set of uk targa blinds for me as I bought a set of uk ones for my zed and they seem to be too big. Would like to check sizes please
Are you sure they won't fit??? You're not trying to put them on the wrong way round or anything like that?? :confused:
If no-one can do it tonight i'll measure one for you tomorrow. :)
IIRC the Jap and UK ones are slightly different
thats what I was led to believe. Bought a set of greg yonks ago and only got around to using them a while back and found they where 'very' tight to fit. hence looking for sizes etc..
They are all the same!
They are marked left and right, so you have to put them on the corrsct side or they wont fit correctly!
Apologies for the crude image (home made) but it may help you. 56cm x 39cm by my measurements.
much appreciated. will check when it stops pissin down lol
Sorry Ray, but you're deffo wrong, got both UK and Japs here, the UK are smaller, 51.5 x 39 ;)
Vijay
By the way i measured a targa blind - not where the blind fits. ;)
I was told they were the same when purchased mine afew years ago, just lucky then! apologies! but they are marked left and right though.
Whoooops!!! Just re-read that - i measured an import blind, sorry. :cry:
Uk are smaller as the actual targa has a plastic block stuck on the front inside of the targa.
As already stated both are different sizes
As is the visual glass area...
Yep, Uk is about a 1-2cm shorter becuase of the Extra rubber/plastic strip on the targa glass
Does anyone know the purpose of the rubber/plastic strip. ?
the ones I got from greg must be jap spec ones as they dont fit too well lol will put them up for sale shortly and look for uk ones
YGPM
