Might be of interest to someone..............
RL traction can be troublesome, it will often 'drop' its program for no readily fathomed reason.
I can supply an alternative that does all that the RL does but for around £650 and that includes Launch and switchable slide, the best bit is the ROM for the settings is safe, you can only set it up from a sequence and code from an external source.
...aswell as initially configuring your setup for a four cylinder car when it should be six and being a git for guessing your wheel diameters correctly aswell!!!
Mine is staying switched off until the nastey stuff starts being deposited from the heavens and then I'll play around with it more.
