Me again.
So I have two questions:
RobHowl ·
a friend has offered me some wheels which are 18" diameter with a stud pattern of 114 and a width of 9.5j...
My question is however, will they fit my Z as they have an offset of 50...
will they stick out past the arches? or sit too far in so that i would need spacers...
cheers guys
