emisions failure on mot possible safc????
my zed failed its ticket on fumes could this be down to the afc set up to run 14psi see my theory is this - its set up to run 14psi but obviously when you rev the engine without load no boost is being used so at 5000rpm theres no boost but its putting in 14psi worth of juice which is big over fueling so would this cause it to fail on fumes ??? advice please if this couldnt be causing what other possibilities should i look at ??? regards jim
  • Replies 26
  • Views 1.2k
:x: :rofl: ;)
