Bleeding Brakes issue
right after the rear brake binding issues (not BMC, calipers, pads, discs etc) the abs actuator from john300zx has been fitted and the bleeding process has begun.
No problems with the first circuit but having great difficulty with the second circuit.
am i doing something wrong???
FL - FR - RL - RR - ABS actuator 2 bleed points
Usually you should always start furthest away from the master cylinder when bleeding and work towards it.
