HELP ! my hazard lights wont stop flashing!
The hazard lights on my 350Z won't stop flashing. have tried alarm, interior switch, key fob, disconnected battery, even replaced battery and the things just keep flashing.
got a toad alarm on it but it seems to work finie still.
lights stop flashing when key is in ignition and it fires up fine and drives. sson as i turnit off ans take key out it starts flashing again :headvswal
Any ideas anyone?
my 2 d's worth alarm fault you could snip the wire from the alarm to indi's
would be a bit ott but they would 'nt flash :rolleyes:
it's startin to look like and idea!
TBH this is a 300zx forum not a 350Z one. You should try over at http://www.zclub.net as they might be able to help you out better than we can.
One thing tho, is it a factory fitted alarm or aftermarket?
I don't think it would matter what car it was tbh. It's a short on the circuit and if your alarm activates the indicators when you arm and disarm it then this is the first thing that needs to be checked.
