turbo fitting
Hi all,
Hopefully i will have my new turbos fitted next week as ive bought sum 2nd hand tubs off yampiedog. What else will i need to fit them do i need any gaskets etc?
cheers
Dan, I have been told that you should also replace the oil feed pipes and it is also probably best practice to replace gaskets.
Deffo replace the oil feeds and gaskets. Also worth replacing the rubber pipes on the water feeds and doing the throttle body coolant bypass while its out :)
ok how much are the oil feeds and gaskets and where can i get these bits from?
Is the throttle body water bypass the same job ive been told to do when ill be changing the injectors??
thanx
Nissan do a gasket set just for replacing both tubs , i paid £116 for the kit not sure about the oil feed pipes , i flushed and cleaned mine out , good as new now :hyper:
