What speed ... at what revs ... in what gear
Guys just a thought. I am trying to solve an intermittent problem with my speedo. And figured it would be useful reference material if I could raise thge back wheels off the ground and bench test the speedo. The car is currently on a SORN while I sort out the work and I dont really want to be fiddling with wires out on the road!!
However in order to do this I need to know what speed should be registered at various revs in each gear.
So what I was going to suggest when you guys are out and about if you can note the following info for various revs and I will collate and post up for future reference:
- NA/TT
- JSpec/UK
- Manual/Auto
- Year
- Gear
- Revs
- Indicated Speed
- Sat Nav Indicated Speed where available
The more we have the more likely we can account for minor inaccuracies in a single person's speedo/data and get decent averages.
I think it would be very useful, any thoughts??
Rich
p.s. if this already exists then let me know (and where I can find it) and I'll be quiet :D
I would find this useful too as my speedo needs some fine tuning after going on bigger wheels.
Will be extra helpful if it it from a digital readout GPS for extra accuracy
there is an excel sheet for gear ratios for the Z32 which tells you rpm per speed , but Im having problems with my Home PC so cant get it...somebody else should have a copy though
Ahaaaaa if someone could share it that would be great ... see not an original idea in me:D
Rich
