protoj ·
11th of November 2007 from 11:30pm - 3:00pm (ish!)
The Angel Inn
188 Ringwood Road
Longham
Dorset
BH22 9AP
All Japanese car types welcome.
Please note: The carpark entrance is on Casterbridge Road (The side road next to the pub!)
A selection of pictures from the last October meet can be viewed here: http://z10.invisionfree.com/djcc/index.php?showtopic=4064 :)
