Adjustable Front Upper Arms
My tyres are wearing on the inner edge and the garage that fitted my new tyres and adjusted my tracking advised me the camber would need sorting if the wear didn't get better.
How easy are these to fit and what is likely to go wrong if I do it myself? :rolleyes:
they are very easy to fit, if you dont count the odd seized bolt!!!
just spray every thing up with WD or freeing compound first. you must get the camber done asap after wards tho. i highly recomend adjustable tensions and rear uppers aswell to complete the package
Mark
Mark
I already have adjustable tension rods and the rear tyres are wearing fine, as I work for BOC i have good access to hot spanners!
Cheers ;)
Use the same ones myself. As said before the old ones might be welded on lol, but once you fit these and with the lower arms really sharpen things up.
Hi mate,
These are not difficult at all to fit but (as stated by silverbullet) you must get it set up professionally asap.
I've got a couple of sets of Powertrix adjustable upper arms on order (roughly 10~14 days before they're in the country) which are slightly cheaper (£215)than the SPL ones (£255) but of identical quality. In fact, I've just sent a pair to Rob-300ZX to replace his knackered ones and he's most impressed with the quality of the Powertrix units. Let me know if you want me to reserve you a pair.
Regards,
Dan
