skyline r32 gtr brakes.. better than original zed calipers?
Hi guys,
a friend has offered some mint r32 gtr brakes in good working order...i know the r33 skyline brakes are a good upgrade but are the r32 gtr brakes better than the zed?
thanks guys.
Kesh
I think they are the same callipers.
I wait to be corrected though.
The only reason they would be any better in that case is if your exisitng ones are not working properly.
Darrell
Darrell
cheers darrell,
just checking on this chaps site from sxoc.he sells big brake conversion's but by the sounds of it he brings the package together himself. can anyone recommend this guy or have used him before?
"330mm Plain big brake conversion
(Uses R32 GTR or R33 GTS-T calipers (not supplied)"
by what his site says above its seems the r32 gtr can house 330mm brakes, as opposed to stock calipers peaking at 315? correct me if im wrong guys. thanks
R32 calipers are probably the same. They can be mated with the larger discs by using offset mounting brackets.
Yep, same as Zed TT calipers. Its the Big brake conversion commonly available for the zed, which uses 330mm Discs and Caliper brackets.
