Any ideas anyone? Is 1366x768 ok?
Cheers!
Humax 40" LCD, £550 1366x768 resolution
http://www.ebuyer.com/customer/products/index.html?rb=0&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=125572
Humax 40" HD Ready LCD TV
16:9 Wide Analog LCD TV
Black
Interactive communication via MHEG middleware
PIP (Picture in Picture) / DS (Dual Screen) functions
Virtual surround audio: multi-functional SRS TruSurroundXT
Common Interface slot
VESA standard wall mounting support (not including bracket)
WXGA video resolution support (1366*768)
Brightness: 500 cd/‡u
Contrast Ratio: 1000:1
Main RCU & Sub RCU (Support Remote Control for Children and the elderly, in addition to the Multi-functional main remote)
Item Description
> LCD
Type Colour active matrix TFT-LCD
Display Area 40" Wide
Aspect Ratio 16 : 9
Driver Element a-si TFT active matrix
Display Color 16.7 M
Resolution 1366 * 768
Pixel Pitch
0.648 (H) * 0.216 (V)
Contrast Ratio 1000 : 1
Luminance of White 500 cd/ (Typ.)
Viewing Angle (CR10) 170° (H) / 170° (V)
Module Size 952.0 (W) * 551.0 (H) (mm)
Depth (D) 51.0 mm
Weight 11.5 kg
Response Time 8ms
> Dimension
Width * Height * Depth 1,235 * 699 * 252 (mm)
> Weight
Net weight 34 Kg
> Sound
Speakers Mono / Stereo / Nicam / A2
Audio Output 7W + 7W (Max.)
> Power
Supply AC 90 ~ 240V
Consumption 300W (working)
5W (stand-by)
> DTT System Resources
CPU Sti
EEPROM 8 Kbytes
> Tuner (Analog)
1 Input Connector IEC-Type, IEC 169-2, Female
Analog Receiving System PAL / SECAM-VS Tuning
Frequency Range 48.5MHz to 219.5Hz (VHF)
/ 529.5MHz to 816.5MHz (UHF)
Signal Level -10 to -70 dbm
Constellation Scale Factor 1, 2 and 4, Non-hierarchical
> Demodulator
Waveform OFDM
Mode 2K, 8K
Codes Rates 1/2, 2/3, 3/4, 5/6 & 7/8
Guard Intervals 1/4, 1/8, 1/16 & 1/32
> Video Decoder
Transport Stream MPEG-2 ISO/IEC 13818
Profile Level MPEG-2 Main Profile @ Main Level
Input Rate Max. 15Mbits/s
Video Formats 4:3, 16:9 letter box (Default)
> Audio Decoder
Audio Decoding MPEG/MusicCam Layer I & II
Audio Mode Single / Dual mono / Stereo / Joint stereo
> Input / Output
Video In/Output 3 SCARTS (Full 2 / Half 1), 1RCA
S-VHS Input Mini Din 4-pin jack
Component Input RCA jack
DVI Input DVI-D
PC RGB Input D-sub 15 pin
PC Audio Input Stereo Jack
Headphone Output Stereo Jack
Common Interface 1 Slot
RS-232C 9 Pin
No posts to show
