Me again.
So I have two questions:
RobHowl ·
Hi Guys,
just fitting decat pipes to my 90TT. What do you do with the Exhaust recirc rubber pipes from the old front pipes?
Do you just tie them up or do you have to block them or do you join one side to the other?
Will I need to do anything anywhere else on the engine IE with EGR valves etc.
Regards
Jase
