Drivers side electric window
My drivers side electric window has taken fits of stops and starts. Could work for weeks then nothing. The black switch behind the door panel is clicking when I try to use it but that's all, the motor won't work. I read on the forum that it probably means the motor is kaput. Does anyone know what other Nissan uses the same motor or where I can get one. CheerZ, S
  • Replies 31
  • Views 1k
yes. you have to remove the door panel. once removed you will spot it straight away. we are all here to help mate. :D
Is there some kind of manual or 'write-up database' for where to find all the different screws/how to take apart parts of the car, etc...?
Thanks again
Squirt some WD40 down the runners this sometimes helps as a temporary fix?
Hope ya got the problem sorted. When I opened the switch there was one obvious joint that was definitely seriously lacking in solder so I did the needful plus re-soldered all the main connections as advised by the boys above. Cheers y'all and thanks again.
Not yet unfortunately! After having wasted so much time with the wrong unit I haven't had a chance to revisit so will have to wait til next weekend now....will keep you posted tho!
