Haynes Maual Translation !
Apoligies if this is a re-post !
Subject: FW: Haynes Manual Translations
> Dear All
> For all the technically minded among you........ENJOY!!!!
> Haynes: Rotate anticlockwise.
> Translation: Clamp with visegrips then beat repeatedly with hammer
> anticlockwise.
> Haynes: This is a snug fit.
> Translation: Clamp with visegrips then beat repeatedly with hammer.
> Haynes: This is a tight fit.
> Translation: Clamp with visegrips then beat repeatedly with a hammer.
> Haynes: As described in Chapter 7...
> Translation: That'll teach you not to read through before you start. Now
> you are looking at scary photos of the inside of a gearbox.
> Haynes: Pry...
> Translation: Hammer a screwdriver into...
> Haynes: Undo...
> Translation: Go buy a tin of WD40 (giant economy size).
> Haynes: Retain tiny spring...
> Translation: PINGGGG - "Where the hell did that go?"
> Haynes: Press and rotate to remove bulb...
> Translation: OK - that's the glass bit off, now fetch some good pliers
> to dig out the bayonet part (and maybe a plaster or two).
> Haynes: Lightly...
> Translation: Start off lightly and build up till the veins on your
> forehead are throbbing then clamp with visegrips then beat repeatedly
> with hammer.
> Haynes: Weekly checks...
> Translation: If it isn't broken don't fix it.
> Haynes: Routine maintenance...
> Translation: If it isn't broken, it's about to be. We warned you...
> Haynes: One spanner rating.
> Translation: An infant could do this... so how did you manage to (bleep)
> it up?
> Haynes: Two spanner rating.
> Translation: Now you may think that you can do this because two is a
> low, teensy weensy number... but you also thought the wiring diagram was
> a map of the Tokyo underground (in fact that would have been more use to
> you).
> Haynes: Three spanner rating.
> Translation: Make sure you won't need your car for a couple of days.
> Haynes: Four spanner rating.
> Translation: You're not seriously considering this are you?
> Haynes: Five spanner rating.
> Translation: OK - but don't ever carry your loved ones in it again.
> Haynes: Bolt will be tight
> Translation: You havent a hope in hell!
> Haynes: If not, you can fabricate your own special tool like this...
> Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
> Haynes: Compress...
> Translation: Squeeze with all your might, jump up and down on it, throw
> it at the garage wall, then find some visegrips and a hammer...
> Haynes: Inspect...
> Translation: Squint at really hard and pretend you know what you are
> looking at, then declare in a loud knowing voice to your wife "Yep, as I
> thought, it's going to need a new one"
> Haynes: Carefully...
> Translation: You are about to suffer deep abrasions.
> Haynes: Retaining nut...
> Translation: Yes, that's it, that big spherical blob of rust.
> Haynes: Get an assistant...
> Translation: Prepare to humiliate yourself in front of someone you know.
> Haynes: Turning the engine will be easier with the spark plugs removed.
> Translation: However, starting the engine afterwards will be much
> harder. Once that sinking pit of your stomach feeling has subsided, you
> can start to feel deeply ashamed as you gingerly refit the spark plugs.
> Haynes: Refitting is the reverse sequence to removal.
> Translation: Yeah, right. But you swear in different places.
> Haynes: Prise away plastic locating pegs...
> Translation: Snap off...
> Haynes: Using a suitable drift...
> Haynes: Apply moderate heat...
> Translation: Unless you have a blast furnace, don't bother.
> Alternatively, clamp with visegrips then beat repeatedly with hammer.
> Haynes: Index
> Translation: List of all the things in the book, except what you need to
> do.
> Haynes: Everyday toolkit
> Translation: AA Card & Cell Phone.
Alan................... :D
No posts to show
