PSI Gauge
In my Z, the standard PSI gauge either reads way off the clock when the electrics + engine is off (past -14) or when electrics + engine is on it reads way above +14 (off the clock again)
But its also limited to 5K revs.
Any ideas why the gauge is being weird and why im limited?
Should be off the scale -14 when turned off, but when you put the ignition on its should be at 0 i think.
............off to look!
Yep as i thought, your guage must be getting a duff signal somewhere.
What does it do when you start it?
Is it on 0 on tickover?
No, on idle its at off past +14.....
It should be at the opposite end on idle
First off id check all your vac pipes are connected, start at the balance bar and work from there.
