protoj · 34 minutes ago 34 min
Drove into the back of a van..... The driver got out and started ranting at me, Just then I noticed he was short enough to be a dwarf.... He looked up at me and said..... "I'm Not Happy!"
I replied..... which one are you then?...... :D :hyper:
