Help!!!!
Hi Could Anyone Please Post A Pic Of The Loom Going Into There Ignition Barrel I Think I Have It Right However There Is Nothing Happening When I Turn The Key? Need To Verify That The Wires Are Position On The Pins Correctly. Or Give Me Some Advice On What Else Would Cause This Problem. No Lights Come On The Dash When Key Is Turned. The Battery Is Fully Charged By The Way. The Head Lights Come On.
Here you go try this link click The head lights will come on without ignition, thats why you get the chime if you have left the lights on. Sounds as though you have blown main ignition fuse check fuses, possibly because you may have wireing wrong?
thanx i will
