inlet cam pulley
how do you get the variable cam pulley off? is the 19mm nut left or right hand thread? it seems pretty tight.
I just done me cam seals and buzzed it off with an electric buzz gun type chap, anti-clock to loosen. Can get you the torque if it helps.
Cheers John
cheers john il attack it with my rattle gun. its just an arse of a thing to hod to stop it from turning.
You may find it easier to lock the pulley! Use a bar if you have no cam sprocket locking tool. Just be carefull. Then you will be able to remove the nut!
i tried locking the cam in the vice but its on tight. i had a peg spanner in the pulley but i couldnt get any purchase on it.
its just tight
its just tight
They are tight! i think from memory they are opposite thread :)
