Fitting BOVs
Is there a thread anwhere n how and where to fit BOVS coz Im completely clueless :confused: :confused: :confused:
Depends which bovs...
HKS super sequential.....apparently
in place of the re circs, thats where mine are, unles you got them on hard pipes?
Er.....and where exactly are the re circs??
take the nose panel off, then the standard air box you should see a round thing right towards the back near the radiator, with a thin pipe comin out of the top, a bigger 1 going into the air box pipes and 1 that goes into the hard pipe (boost pipe) remove that it should have a part number on it like (REC) then some numbers, then the pipe that comes from the hard pipe is the 1 you want to use, the air box pipe is the 1 you block off and the thinner pipe is the vacum pipe this goes onto the little nipple on the BOV. Hope this helps mate.
Cheers bud helps a lot ;) ;)
no problem if you get stuck let me know i only done mine about 3 months ago ha ha
thats a good link that carl
If you need any help, advice I've just done mine.
You'll have to remove everything out of the way to reach the recir's. Also make sure you have nice new jubilee clips.
It's a real PITTA.
All the best
Eileen
