protoj · Tuesday at 18:48 2 days
Japnortheast April 15th Sunderland Meet
Its that time again
decision was made to make this meet the third week end of April due to Donny show....
Car of show will be held each month throughout the year, based on transmission,
one month Front Wheel drive
one month Rear Wheel drive
one month 4 Wheel drive.......................then return to Front Wheel drive...
The month of April Car of Show will be The Four wheel drive cars.......
Car of the show list - http://www.japnortheast.co.uk/forum/index.php?showtopic=14587
April the 15th at the Stadium of Light, starting at 2pm running until whenever everyone leaves!
Usual mix of stunning Jap Cars all the regulars and much more, Standard attendance now reaching a constant 150+ Cars, Burger van in attendance, JNE Raffle & much much more. We would love to see you all there
Please add your name below if you wish to attend!
Regards
The Admin Team
Convoys to SOL
Details for Teesside convoy : http://www.japnortheast.co.uk/forum/index.php?showtopic=14584
Details for South Sheilds convoy: http://www.japnortheast.co.uk/forum/index.php?showtopic=14582
Details for Chester-le-Street convoy: http://www.japnortheast.co.uk/forum/index.php?showtopic=14583
Details for Ashington convoy: http://www.japnortheast.co.uk/forum/index.php?showtopic=14585
