plugs NGK PFR6B-11C on an NA
Are these correct?? what would the implications be if they are wrong.
they were changed when i bought the car and seem to be burning correctly.
Wrong ones mate, they is for a TT. Heres the codes below.
http://www.300zx.co.uk/forums/showpost.php?p=859833&postcount=13
As for what will happen, fraid i dunno...
cheers
smithy
thanks smithy :bow: Thought they were. shame as they look like new and burn is clean. anybody know the possible implications with running these plugs. i have been for over 2 years :rolleyes:
Gaz,
If they have been in for 2 years and are still "as new", the answer is probably none . I think you would only get a problem if it's the other way round,i.e N/A plugs in a turbo engine. Due to the higher combustion temp the tip of the spark plug would burn away.
Keith
Gaz,
Keith
good good thanks keith. :dance:
Hi there, unlikely PFR6B-11C will cause an issue in an NA, you've proved that by running ok for 2 years anyway. Slightly higher possibility of cold fouling but less chance of thermal damage thanks to the extended shroud on the threaded shell...
Would anyone care to comment on the thickness of the head? PFR6B-11C has an extra 2mm of shroud - never having seen this from the combustion chamber side of the head I'm not sure whether this actually stands proud of the combustion chamber surface or is flush with it.
I'll get me anorak...
2mm longer than which ones bud ? what are you comparing them to
smithy
There's a 2mm shroud on PFR6B-11C when compared to PFR6B-11, projection and overall length is the same. If the thickness of the head is identical on NA and TT then either the threaded shell will finish 2mm shy of being flush with the combustion chamber surface for PFR6B-11 or will be 2mm proud of the surface for PFR6B-11C (or I guess each plug thread could end 1mm either side of the cc surface...).
H!
