can these brakes be used on the zed??
saw these on ebay, they are for an evo 6
with 330mm disks & 6pot calipers
im guessing the pcd will be diffrent will they??
any good for the zed or are the gtr ones much better
PCD is the same I think, 5x114 for most jap cars but bet the mounting points on the calipers are different.
you can get some mounting brackets from EBAY.com (usa) ;)
well, you used to :confused:
are they as good as the skyline gtr setup
Better !! The standard EVO and skyline setup are almost identical (324mm , 4-pot Brembo) but the setup you have described is an Aftermarket Big Brake upgraqde for Evo's, so will be quite abit better than the GTR upgrade.
You will need to get Mounting brackets custom fabricated.
