Me again.
So I have two questions:
RobHowl ·
WAS RUNNING - NOT PERFECTLY PRETTY LUMPY AT TIMES?
NOW CHUCKED IT & NOT STARTING (TRIES REALLY HARD THO!!
FUEL IS RUNNING AND INJECTORS ARE CLICKING BUT NO SPARK
PLEASE HELP !!!
I OWNED THIS CAR 4 YEARS AGO AND HAVE JUST BOUGHT HER BACK!!
THE JOYS - THE TROUBLES!! :headvswal
