Another, issue I'm doing well tonight. Cruise!
My car has cruise control, which doesnt work.
When the cruise button on the right hand "bank" of controls is pressed the system engages, well the light comes on and "cruise" is illuminated.
However it doesnt seem to responsd to set, resume etc etc....
So to cut a long story short, i noticed that the edge of the top of the steering wheel trim was loose, i figure no worries just pop that back in. On taking the cover of the steering wheel of i noticed that the cruise buttons wernt plugged into anything, furthur more the connector for them to plug into has gone (you can all see where this is going....)
Where should it be? Is it possible its dropped down the steering column?
(the horn has also been moved on my Zed, to the top of the steering column)
Are there any reasons for this move? Seems strange to me. Unless at some stage its had a non standard steering wheel on, and never been reconnected. What do you think?
have you got the actuator under the bonnet?
left side next to number 17 it has a black ball like thing then a cable leading from it?
Is that the badger ringed in red?
just checking LOL
thats the one its connected to the greeny actuator which holds the throttle open. i wanted to see if your car actually had it .
lol comeon, i'm not quite that bad ;)
It has all the buttons for it, its just the 3 on the steering wheel are not connected, and i cant find where it plugs in lol (it has the "on off" switch on the right hand side to enable the system, and the "cruise" light comes on in the instrument cluster
