oil pressure and temp gauges?
what do i need to get these to work?
i have sumthing about a sandwhich plate or sumthing?
any info would be great thanks:)
The sandwich plate locates between your oil filter and the car, it allows you to fit aftermarket senders (ie..more relaible ) you then connect to your aftermarket gauges. HTH
Yup, the plate comes with 4 threaded ports on it (you can see 2 with bolts in in the picture) which have plugs in them, you can choose with port suits you best. If I can get under the car later, I'll take a picture for you.
